A kernel notification was received containing invalid or corrupted data. The notification was dropped.
This is an internal socket library issue. Please try the following: check protocol and interface configuration, restart the protocol, reboot the system. If the event still occurs then contact technical support with the output of "show tech".
Error
A kernel notification containing invalid data purportedly from virtual i/f %p1% has been dropped.
| Name | Type |
| p1 | uInt32 |
